Electric Water Pump Wiring
Old Mar 24, 2005 | 06:42 PM
StangInRearView's Avatar
After discovering why my power steering was weak, i bought a CSI electric pump. I have the barry grant relay, but im not the greatest at electronics. I have it wired and operating, but i cant figure out how i would put a switch in and an LED. I have the diagram that shows for the switch i need a hot wire with diode and a 12v wire. There are 6 prongs on the back of the switch , numbered 1-6, can anyone tell me which numbers i would connect the wires to, and if i need a ground anythere. It is a normal toggle switch with light or anything. Secondly, for the led, i know i run a line off of the pump power though a diode, i have an led with a resistor in it, how would i wire this up?
thanks for all the help
Old Mar 24, 2005 | 08:10 PM
slopokrodrigez's Avatar
Re: Electric Water Pump Wiring
Fax the schematic for the wiring and any switch diagrams to 757-826-7597. I'll draw up directions tomorrow on what you need to do. But I have to have a switch diagram. If you have nothing on the switch, take a digital pic and email it jamianddave@charter.net. If you can scan the schematic, you can email it together to the same address.
Old Mar 24, 2005 | 10:17 PM
TheHeadFL's Avatar
Instead of the simple LED, I reccomend you use this kind of setup:
http://mywebpages.comcast.net/khartn...02/circuit.htm
Old Mar 24, 2005 | 11:09 PM
texanmutt's Avatar
I got me one of these-
http://www.autocontrolinc.com/watchdog
Much easier to install.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
