electric water pump install question
Old Aug 23, 2004 | 08:46 AM
Gripenfelter's Avatar
My CSI didn't come with install instructions.
Do I have to remove the waterpump gear as well? Will it give me any extra hp if I do? Logic would say yes but if its less than 1hp I wont bother lol.
Old Aug 23, 2004 | 09:01 AM
izzyz28's Avatar
Re: electric water pump install question
As far as I know you can just leave the gear and shaft in there. Otherwise you'd have to remove the timing cover. You'll have to press the impeller, shaft, and bearing out of your factory water pump. You'll then have to seal the driveshaft hole with a freeze plug and I would recommend some JB Weld too. It's really not hard at all. Oh yeah, when I installed my Meziere I had to trim the fan shroud. Your CSI pump is probably the same size, so you'll have to do a little trimming too. Good Luck.
Old Aug 23, 2004 | 09:56 AM
Compstall's Avatar
My gear's still in there.
Old Aug 23, 2004 | 03:09 PM
speedmiser's Avatar
http://ken.lowrance.com/projects/CSIwaterpump/
Old Sep 11, 2004 | 10:44 PM
Birdman7389's Avatar
perfect! I was looking for one of those!
Old Sep 11, 2004 | 10:59 PM
ledfootz28's Avatar
i left mine on there also when i did my csi wp.i even had the timing cover off but didnt think it was neccessary to take that shaft out.
Old Sep 12, 2004 | 12:59 AM
Z-RATED94's Avatar
We took the shaft out on mine, but put the bearing back in. I really don't think it makes a difference.
Old Sep 12, 2004 | 03:56 AM
GhostZ's Avatar
Iput in a freeze plug
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
