Electric water pump help!!
Old Aug 27, 2006 | 05:20 PM
00JoeZ28's Avatar
Does anyone have any diagrams on how the maziere electric pump is wired to it's relay? Which out of the four plugs on the relay does the red wire connect to and which does the black connect to before it's grounded?
And my radiator is making burbing and gurggling sounds aswell. I purged the system and it still makes those sounds. I think my pump may be wired wrong and is spinning in the wrong direction. Can anyone please help me so I can drive my car.
Old Aug 27, 2006 | 06:16 PM
Blue96z28's Avatar
Re: Electric water pump help!!
Here is a diagram:
http://ken.lowrance.com/Projects/CSI...ectricalHookup
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
My car also makes thoose noises, both when hot and just killed, or just pumping cold sometimes, so I assume its normal, been that way for at least 15k, perfect running temps.
Old Aug 27, 2006 | 07:27 PM
00JoeZ28's Avatar
This is a new motor set-up and I had it runnig for like 6-7 min. and the water temp guage neddle was just under red as I freaked out and shut the motor off. It was then when I heard the churning of the antifreeze and the hoses where even shaking as all the noise was being made.
Thanks for those diagrams.
Old Aug 29, 2006 | 03:16 AM
blown383's Avatar
After you fully flush the system you'll have to "burp" the system. Meaning bleeding it several times. You won't be able to get all of the air out till the thermostat opens.
-B
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
