Electric water pump fuse getting hot
Old May 16, 2006 | 10:35 AM
craigffb's Avatar
Anyone have any ideal of what would cause the in line fuse in an electric water pump to get hot? I've had the pump for about 4-5 years and occasionally the fuse will over heat and pop. The in line fuse, the way I have it set up is in line between the pump and the relay. So there is basically one hot wire running from the pump to the fuse then to a relay that allows the pump to come on with the ignition. The wire from the pump to the fuse is getting hot as well as the fuse, but not the wire that jumps the fuse to the relay. Any help would be appreciated.
Old May 16, 2006 | 10:50 AM
evilundisguised's Avatar
Re: Electric water pump fuse getting hot
Are the wire segments the same gauge? Is the fuse properly sized for the pump?
Old May 16, 2006 | 11:00 AM
craigffb's Avatar
Yes and yes. The more I think about it, the more I think the pump may be working to hard and pulling to much power to keep it spinning. Like maybe a bad barring or gunk/deposits on the blade or something.
Old May 16, 2006 | 11:06 AM
Sounds possible, but doesn't explain why only the wire segment before the fuse heats up, and why it's intermittent. The only reason that could be happening is if the wires are different or there is a short to ground at the fuse. Can you get a clamp-on ammeter around each of them? This will tell you current draw through each and through the pump as well.
Old May 16, 2006 | 05:04 PM
craigffb's Avatar
Talked the tech guy at CSI/CSR and he said he thought it was a drag on the pump making working harder, which is kinda what I was starting to think. He said to send it in for warranty work. $60 tops. Sounds like a pretty good deal to me.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Queens94z28
Dec 20, 2014 09:11 PM
