Electric water pump?
Old May 8, 2008 | 06:30 PM
pologreen94z's Avatar
who has used a summit ewp and are you happy with it? my brother hasnt been able to find much info on it. just trying to find out some info before i get it.
Old May 8, 2008 | 08:49 PM
96capricemgr's Avatar
Summit parts are going to be made by someone else. Seeing as Summit Meziere and CSR are the only three LT1 electric WPs I can think of and both of the others seem reasonably reliable I do not think the summit can be too bad.
If someone knows of another manufacturer I am all ears.
Old May 8, 2008 | 09:03 PM
IROCThisZ28ForLife's Avatar
yeah summit uses other companies and throws their name on it for cheaper, but basically same product
Old May 9, 2008 | 02:40 AM
ImportAssassin's Avatar
meizerre makes a good one, summits is cheaper and doesnt flow as much, and its only like 20 less so i would go with the name brand if your only spending 20 dollars more
Old May 9, 2008 | 07:00 AM
ghost97ta's Avatar
water pump
the summit is the same as the csr wich i have and works great.also if you
get it get the painless relay kit it makes hooking it up easy.
Old May 9, 2008 | 07:06 AM
ghost97ta's Avatar
install
i almost forgot you need a dremall becuse have to fit the pump to the housing and press a freeze pug in where pumps shaft goes and you have
to have the shaft pressed out hope this helps you
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
