electric water pump?
Old Mar 16, 2004 | 01:24 PM
RedWS6TA's Avatar
were does everyone run there power wire to?
Old Mar 16, 2004 | 02:09 PM
IslandZ's Avatar
Put a relay from to get the power straight from the battery and I used the cruise control in the fuse box under the hood to activate the relay and get power straight from the battery.
Just be sure you put a fuse as close as possible to the battery.
Old Mar 16, 2004 | 04:15 PM
1BadBrd's Avatar
i think i went with the injector fuse under the fuse box
Old Mar 16, 2004 | 04:55 PM
Spinner's Avatar
Pump power directly to battery. Relay power to IGN fuse, so pump only gets power when ignition is on.
Old Mar 16, 2004 | 04:57 PM
FastZinTennessee's Avatar
Pulled up the fuse box under the hood on the drivers side, tapped into a heavy gauge orange(accessory) wire.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
