electric problem
electric problem
i posted this in the audio forum already and haven't had any responses for a while, and was hoping someone in this forum might be able to help me. well, i was taking out my head unit and i touched a hot wire with the ground wire. sparks flew, and now my keyless entry doesn't work, my reading lamps don't work, and the chime that goes on when i leave my lights on don't work either. i have since changed every 25,20, and 15 amp fuse in the fuse box inside the car. does anyone have an idea of what my problem is? could this just be a bad ground? thanks for any input.
kearn
kearn
Sounds like you missed one last fuse. Check fuse 9 (gages) which is 10 amp. Although I don't see how messing with the radio would have screwed this one up. It does go to the keyless entry system, The audio alarm module and part of the instrument cluster.
eanhl2004
Apr 4, 2015 12:01 PM
