electrc water pump users!!
Old Jul 11, 2005 | 05:14 PM
ddlouhy127's Avatar
what is involved in installing one? and how do you plug that hole that i hear about? thanks
Old Jul 11, 2005 | 09:23 PM
2nd_chances's Avatar
Re: electrc water pump users!!
the Meziere comes with a freeze plug to press in the hole left by the stock pump shaft.
Old Jul 11, 2005 | 09:32 PM
simple's Avatar
press out the old waterpump shaft from the housing (can be a bitch, can be a cake walk)
install new pump on housing (CSI requires a little dremel work for the 6 tiny ears for it too fit correctly, no biggy)
take the supplied freeze plug and press it into the waterpump housing hole that is left by the old shaft drive on the back side (mezeir and CSI come with one)you will need to go to a parts store and purchase another freeze plug too fill the timing cover hole (1 1/16" or 1 1/8" cant remember for sure)
reinstall housing onto motor
wire it up
theres a tad bit more too it but nothing major
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
Zone
Jul 29, 2002 07:43 PM
