Which elec water pump is better?
Old Feb 18, 2003 | 03:21 PM
  #16
stevil's Avatar
Originally posted by ScottZ
They are both supplied the same motor, by the same supplier. They both use the OE housing. The only difference could be in the impeller design. Mezier has been building LT1 pumps longer, and did have a seal problem orginally. They fixed it a while back (before CSI has their pump, I believe). They're both made in the USA...
Makes you wonder why the Meziere costs so much more, doesn't it?
Old Feb 18, 2003 | 03:49 PM
  #17
RamAir95TA's Avatar
I was going to say...the only difference between the two pumps is the housing and impeller. The motors for the two are exactly identical.
Old Feb 18, 2003 | 03:53 PM
  #18
Mindgame's Avatar
Anyone have pics of the impeller in the Meziere? Not too impressed with the impeller in the CSI model. If you look at the really good OEM impellers that have come out over the years, they have a "scroll" type (curved) impeller. Same thing with the new Moroso electric pumps. Too bad Moroso doesn't make a pump for the LT. I think that'd make for a more efficient pump but that's just my common-sense-engineering at work and that's been known to be wrong at times.
Any engineers out there want to expand on that theory??
Any pics of the Meziere would be cool for comparisons though.
-Mindgame
edit: link to the Moroso electric pump and its impeller
http://www.moroso.com/catalog/catego...?catcode=29300
Old Feb 18, 2003 | 03:58 PM
  #19
RamAir95TA's Avatar
Here's the impeller on a Meziere:
http://www.projecttransam.com/waterpump/mz_pump1.jpg
Old Feb 18, 2003 | 04:11 PM
  #20
Mindgame's Avatar
That to me looks like a better impeller RamAir. Maybe Chuck, Oldstroker, Injuneer or another of these engineering guys will chime in on what makes an efficient impeller.
From what I've read, the curvature in the impeller makes for an impeller that has less current draw and moves more coolant at the lower rpms. The Mez looks better though.... in my opinion.
Thanks for the pic!
-Mindgame
Old Feb 18, 2003 | 04:23 PM
  #21
ba96ta's Avatar
I've had the miezere for awhile know no proubles but if I had it to do over I would get the CSI for price alone I think it looks better also.
One more thing did you guys notice your engine running any cooler afterwards because if anything mine seems to heat up quicker know when I am at stoplights and the strip I end up running my fans alot more often
Old Feb 18, 2003 | 04:41 PM
  #22
Red95Formula's Avatar
I just did heads/cam (CC306) with the CSI pump and my temp is still around 175 when cruising and 180-185 while stopped. I went with the CSI because of $ also.
Chad
Old Feb 18, 2003 | 04:42 PM
  #23
Mindgame's Avatar
Using the Meziere myself but I didn't think much about it when I bought the thing. Just figured they were both pretty much the same... then again, I've always used Edelbrock mechanical or belt drive pumps.
The price is so close between the two that I'd want the most efficient pump. Then again, maybe the differences there are minute as well.
-Mindgame
Old Feb 18, 2003 | 07:18 PM
  #24
ba96ta's Avatar
I thought the electric pumps were supposed to be a great cooling mod but my cars cooling system doesn't seem to be any cooler
Old Feb 18, 2003 | 07:42 PM
  #25
DjArcadian's Avatar
The electric water pumps don't really increase cooling. I think, in part, because it pushes the water through the radiator so quickly that it doesn't have enough time to cool properly. It frees up the CAM to increase power and is needed for aftermarket CAMs. That's the real need for these. For cooling you should get water wetter, your fan temp lowered and a 160 stat of course.
Old Feb 18, 2003 | 08:17 PM
  #26
Dr.Mudge's Avatar
Originally posted by DjArcadian
I think people here use the Meizier more because there's a few online guides explaining how to install it whereas the CSI has no online guides. The Meizier also just bolts on. No modification to the water pump housing. SOme people (myself included) are kind of put off by that. I don't see why CSI couldn't have built it so it bolts right one.
You can use the same install guide, other than grinding the housing a bit. For saving $65, getting what I believe to be a better pump, its worth a little more work IMO, YMMV.
Old Feb 18, 2003 | 08:20 PM
  #27
Dr.Mudge's Avatar
Did you totally bleed the system? I pretty much run 179º all the time, if anything I should raise my fan #1 point because I dont need to run that cool. I run almost no coolant, 5-10%, if you live in a very cold/hot climate though, you may not be able to do that. The boiling point is still high enough with the stock cap that I am completely in a safe zone.
Old Feb 18, 2003 | 08:21 PM
  #28
Dr.Mudge's Avatar
Unless somebody is fibbing, the CSI draws a tad less current, and is rated to last about 1,000 hours longer, last time I looked at the specs.
I haven't heard of a single failure that I can recall, people complained about the seals but I use a bit of blue RTV along with it, not a single issue for me with the CSI.
Old Feb 19, 2003 | 08:54 PM
  #29
ChuckZ28's Avatar
The really nice thing about the electric pump is it allowes you to get a true double roller timing chain which will save lots of MONEY compared to the LT1 and LT4 timing chain. I got my timing chain for 90 bucks and its much better than the crap stock LT1 chain!
Old Feb 20, 2003 | 09:53 AM
  #30
97 RedSS's Avatar
I have been very satisfied with my Meziers the last 2yrs Ive had it..I run mine off a relay and I have yet to have any problems with mine(knock on wood) My temp runs between 165-170 ALL the time even in Dallas traffic..I believe mine is a HD Mezeirs also
Cody
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
