Eibach Drag Launch kit and now my rear is twisted.
Old May 30, 2003 | 04:51 AM
revtime's Avatar
Ok, a little background.
I have the tranny out so the torque arm and driveshaft are out of the car. I decided to put the rear springs and shocks on while waiting for my headers to come back from Jet Hot. Got the rear Eibachs in, was a real PITA, and the KYB AGX rear shocks in but now my pinion is pointing at the sky and when the rear sits on the ground the springs are not straight up and down but the lower spring seat is tilted back and the springs are bent a little, now I have my floor jack on the lower mount for the Panhard rod and jacked it up which tilts the rear forward and lines everything back up.
The question is did I do something wrong or will it all line back up right when I put the Torque arm back on?
Will it damage the coil springs to be tweaked like that?
Old May 30, 2003 | 04:55 AM
Soma07's Avatar
Re: Eibach Drag Launch kit and now my rear is twisted.
Originally posted by revtime
...or will it all line back up right when I put the Torque arm back on?
Yes
Old May 30, 2003 | 05:55 AM
The only purpose of the torque arm is to keep the rear axle assembly from rotating. Correctly set, it holds the relationship between the pinion shaft and the driveshaft approximately constant, and controls pinion angle. Remove the TA and there is nothing to keep the TA from rotating out of position.
Old May 30, 2003 | 02:15 PM
revtime's Avatar
Cool.
Thanks Guys, I thought I really screwed somthin up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
CARiD
Feb 9, 2015 09:35 AM
Dec 4, 2014 11:56 AM
Dec 1, 2014 08:08 AM
