EGR valve??
Old Nov 18, 2003 | 03:30 PM
BigTed187's Avatar
EGR valve??
I scanned my car this morning and code 32 came up?? soo im assuming the EGR valve is not working correctly or at all...i have a rough idle and horrible hesitation when accelerating?? i was wondering if anyone has any input on what else could be wrong?? i also have a pinging of two metals hitting together when i take off?? thanx alot
kevin
Old Nov 18, 2003 | 04:41 PM
ttopz28's Avatar
Last I recall Haynes noted those symptoms (rough idle and hesitation under light acceleration) for....you guessed it - your EGR valve. I had an EGR code too - it took me forever to finally realize where the damn thing is though. (I have pictures if you want them)
To check it, the manual suggests pushing the diaphragm (sp.) in/up while the car is idling. It should stumble. If it does, that verifies that much is working >> I would check all your vaccum lines at this point to make sure they arent broken/come off. The manual then tells you to take the vaccum line off the top and using a vaccum pump to verify that is working. If so -- your valve is fine. Move on to the solenoid or the lines connecting to it.
Edit: i'm no expert in this field, just shedding some light (at least as much as I have)
Old Nov 18, 2003 | 05:08 PM
Hyperspeed97z28's Avatar
I've got an EGR for sale on ebay right now, Took it out when I did headers and !AIR.. Match the # on your current EGR to this #
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443188390
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
