clutch vibration at 85mph +
Old Nov 18, 2003 | 01:40 PM
cz28s's Avatar
when i hit 85mph+ the clutch pedal and the shifter start to vibrate rather hard. It even continues to vibrate when i put it in neutral at 85mph+. whats the deal? Thanks for the help fellars Cory
Old Nov 18, 2003 | 01:45 PM
BradZ28's Avatar
It's probably the driveshaft.......
Old Nov 18, 2003 | 03:06 PM
cz28s's Avatar
uhhh what about the driveshaft? solutions?
Old Nov 18, 2003 | 03:36 PM
BradZ28's Avatar
On your avarage LT1 the stock steel driveshaft can become unbalanced over time. A couple options to remedy the problem are getting an LS1 driveshaft or a 1LE driveshaft. Both are made of aluminum and seem to work well with stock applications. Our steel driveshaft is probably stronger though.....
Another option is a carbon fiber peice but they're around $800.
A search will provide alot of info.
Brad
Old Nov 18, 2003 | 04:24 PM
drewstealth's Avatar
The best option is either try to get it balanced or get a brand new 1le(since it is stronger then the ls1) or get a used ls1 DS. I'm in the exact same situation you are right now. I'm trying to find a used ls1 ds right now. Whatever you do don't get the carbon fiber ds. Carbon fiber Ds's are good but not the ones you get for around 700-800 bucks. THe good ones are around 1500. So you would be better off getting the aluminum 1le.
Old Nov 18, 2003 | 05:13 PM
Hyperspeed97z28's Avatar
Buy a used 1le, thats what I'm gonna do, I have the same issues as you do. the 1le is stronger then the ls1 shaft. and cheaper
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
autoxr166
Sep 25, 2015 04:21 PM
