EGR tube to header gasket?
Old Apr 8, 2004 | 02:43 PM
mkent's Avatar
i'm wrapping up the header install on my AS&M's. i don't recall if there was a gasket between the egr tube and the exhaust manifold where the connect. it looks like there should be a gasket there, but should there? if so, will copper rtv work?
Old Apr 8, 2004 | 02:54 PM
Yes, there should be a gasket and I would use one over RTV. MHO.
Old Apr 8, 2004 | 03:15 PM
mkent's Avatar
are you talking about #14 on that picture? if so, i'm talking about the other end of the tube, and i don't see the gasket on that end of the tube in that picture.
i really don't think there was one on the stock manifold but i don't know how else it could have sealed
Old Apr 8, 2004 | 03:26 PM
pat97SS's Avatar
I did not have a gasket where the EGR tube meets the header on my AS&Ms. The EGR tube fit into the hole on the header. I just bolted them together. If mine leaks I cannot feel it nor was it "blackened" like it gets from an exhaust leak.
Old Apr 8, 2004 | 05:46 PM
Larnach's Avatar
No gasket is needed... I used some sealant on mine, but since its a machined fit, no gasket should be necessary.
Mine worked fine with just a single tightening down and I have had no leaks.
Old Apr 8, 2004 | 06:42 PM
My apologies, I read your post too fast. Obviously, there is no gasket shown for the other end.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
thenewkid
Nov 18, 2014 12:57 PM
veryslowfbody
Aug 22, 2002 04:31 PM
