EGR soda can mod?? help
Old Aug 25, 2003 | 04:19 PM
CoUnTryMuZiCZ28's Avatar
I found a website that said i can make a block off plate for the egr VALVE with an aluminum can... I thought there would be too much heat generated that it would melt it... can i do this or not. I dont have the money for the rest of the block off plates.. everything is blocked off but that.
Old Aug 25, 2003 | 04:45 PM
twdz28's Avatar
I went to Home Depo and bought a 6X6 of sheet metal... Took my Dremal out and went to work... Looks good to me and no problems at this time...
JWA95TA's Avatar
Re: EGR soda can mod?? help
Soda can I used was for the EGR tube side of the intake, not the actual valve. The tube has a metal plaate with a hole in it the tube went through. Cut off the flanged edge of the tube so you can slide the plate off of it. Then cut a piece of alum off a sada can that is about the same size. THen use RTV sealant to seal it to the plate and intake. THis will block the hole off that the EGR tube used to go.
You wouldnt need to worry about heat melting it becuase you dont have exhaust flowing into your intake anymore.
jason
Old Aug 25, 2003 | 05:34 PM
I already have the tube blocked, i just need the valve blocked. I was thinking that with the heat off the intake alone would melt it. not to mention the air pressure in the intake i thought it would make a hold through it. Should i make a gaskt for it and then trace the egr valve since i have it out right now, or should i just stuff it full of jb weld and put a flat block ontop of it so it stays level and then put it back on? problem is i dont have any jbweld
Old Aug 25, 2003 | 06:40 PM
You're gonna seal off a port into the intake with a soda can? Why make potential trouble for yourself? If the block off for the EGR leaks, you wil have symptoms just like a stuck open EGR valve. If your EGR valve is stil on there and no vacuum lines are connected to it, it is basically a big, ugly block off plate (assuming it is not already stuck open). No need to do anything if you are so strapped for cash.
Anything worth doing is worth doing right.
Old Aug 25, 2003 | 07:47 PM
I have all the vacume lines still connected to it... I was going to leave it on there and keep the lines connected but just block it. I have a very ruff idle and my car is throwing code 32 no light though.. scaned it and it says egr and no other problems, just changed the map sensor and rebuilt throttle body... recently started AFTER i put the headers on WHEN i disconnected the egr feed tube.it didnt do it after the header install only when i got around to removing the egr feed tube. my friend had the same problem and said it was the egr still being there and when he blocked it, it fixed, so im all gunho about blocking this darn thing.lol
Old Aug 25, 2003 | 07:51 PM
Kain's Avatar
I made mine out of sheet metal too. Used a little card board gasket with some high temp RTV to make sure it sealed extra well.
marlar98
Oct 21, 2015 02:02 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
Pwilson59
Sep 3, 2015 08:47 PM
CARiD
Jul 7, 2015 08:19 AM
