EGR simulator schematics ?
Old Mar 15, 2005 | 04:20 PM
trax's Avatar
Question EGR simulator schematics ?
I ran across a couple of posts talking about building OBD2 EGR simulators, but I haven't had much luck actually finding schematics. I've seen a couple descriptions saying:
Unplug the 2 wire weatherpak going to the EGR solenoid, and splice it onto a relay.
From the other side of the relay:
--Splice one wire to the rear of the MAP
--Splice the other wire to the middle using a 75 ohm resistor.
I'm not very good with electronics, but does this require a DPST solenoid? I'm not seeing how this can be done with SPST.
Old Mar 15, 2005 | 05:30 PM
Raped Ape's Avatar
Re: EGR simulator schematics ?
Check your email. Someone had given me a schematic a while back, but I never got around to it. Good luck. Let me know if it works out for you.
Old Mar 15, 2005 | 07:03 PM
trax's Avatar
Thanks!
I wired it up and reset the codes on my car. Interesting observation: EGR, O2's, and Heated O2's no longer show up as "ready". The PCM isn't throwing a code though either. I'm wondering if it's because I didn't let the car have a complete cold start... hmm...
I'll have updates tomorrow.
Old Mar 15, 2005 | 07:47 PM
jchevy's Avatar
I wired this up on my car. For me it worked around town, but i would still get the code on long highway drives. I finally just deleted it from the PCM.
Old Mar 16, 2005 | 05:56 PM
trax's Avatar
Ok guys, update. I cleared the PCM and drove 25+ miles (including a bit of cruising on I-90) without any problems. I used a slightly different resistor (68 Ohms, available at Radio Shack) with no problems. Also, the EGR readiness monitor showed up as "ready".
Old Mar 16, 2005 | 07:04 PM
Raped Ape's Avatar
Sent you a pm trax.
Old Mar 6, 2007 | 07:09 PM
trax's Avatar
2 year bump! lol
Raped Ape sent me a copy a while back, but now that I need them again I can't find the file. Anyone else have a copy?
Thanks!
Old Mar 7, 2007 | 01:03 AM
trax's Avatar
Well, I made this one from memory. Let me know if it needs any corrections.
Old Mar 12, 2007 | 09:01 PM
trax's Avatar
Bump... any comments?
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
