Egr Remove
Old Aug 20, 2005 | 02:29 PM
JAG05's Avatar
Egr Remove
When you take the EGR valve off what are you suppose to do with the vacum line that runs into the valve?
Old Aug 20, 2005 | 02:51 PM
Re: Egr Remove
Put a vacuum cap at the manifold fitting or replace the fitting with a plug.
Old Aug 20, 2005 | 03:48 PM
Robs97Z28's Avatar
Re: Egr Remove
Why take off the EGR? It will not increase HP. It also can damage the engine by raising the combustion temps.
Old Aug 20, 2005 | 04:16 PM
JAG05's Avatar
Re: Egr Remove
Becuase mine was missing up and threwing codes and a new one is over a hundred dollars and its $25 for block off plates.
Old Aug 20, 2005 | 04:21 PM
JAG05's Avatar
Re: Egr Remove
http://shbox.com/1/EGR_solenoid.jpg
So can I take off the vacum hose harness and the lines?
Old Aug 20, 2005 | 04:27 PM
jah1542's Avatar
Re: Egr Remove
I don't know where you're shopping for EGR valves, but mine went out 2 months ago, and I got one from O'Reilly's for $50. I'm with Robs97Z28, it's not really worth it. You get no power, and it's not that much more expensive. Pay another $25-30 more than what block-off plates would cost, and you'll get the peace of mind of knowing you're not going to start getting detonation. Just my $.02
Old Aug 20, 2005 | 04:59 PM
Re: Egr Remove
You can if you plug it at the manifold. Of course, you aren't guaranteed that your PCM will not throw codes for having the EGR missing.
A new valve is only $43 at dealer wholesale and $85 retail.
Old Aug 20, 2005 | 06:15 PM
ulakovic22's Avatar
Re: Egr Remove
If you are tired of dealing with codes then getting rid of it won't solve your problem. The PCM will still throw a code since it is missing. If you are bent on getting rid of it you more than likely will have to get it tuned out of your PCM. You can get a tune from several people on the board that will give you more power/torque, get rid of your EGR and what ever else you don't want. If I remember correctly it would be around $125. Yes that is more than a new EGR, but you are actually getting something in return instead of getting rid of your SES light.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
