egr removal
Old Feb 3, 2004 | 08:43 PM
gtheftz28's Avatar
egr removal
does this provide any gains and what are the benefits/reprocusions of removing this?
Old Feb 3, 2004 | 08:51 PM
SlickBlack Z's Avatar
If yours isnt giving you problems (SES light)...then just leave it alone. There is no horsepower benefit from removing it.
Old Feb 3, 2004 | 08:55 PM
S.J.S.'s Avatar
0 Horsepower, just one less thing to worry about. I removed mine along with the air pump but only because I was rebuilding my motor and was in there any ways. Other than that just leave it. Cause if you remove it then you gotta go get the comp redone and stuff.
Josh-'04 GTO's Avatar
Zero horsepower gains, since EGR is non-functional at WOT anyway. I did it to ditch off some stuff that I felt was not needed. On a stock car, you'll have trouble passing NOx tests without EGR. If you have an aftermarket cam, however, there is a good chance that the overlap built into the cam will actually render the EGR unnecessary. So less engine compartment clutter and a few pounds of weight savings are pretty much the only benefits.
Old Feb 3, 2004 | 09:23 PM
ibanez6rg's Avatar
Weight savings! Wheelie!
Old Feb 3, 2004 | 09:29 PM
Between the valve, tube, and solenoid it was at LEAST 2 pounds! Woohoo!
Alright....it wasn't very exciting or rewarding. But it did give me something to do!
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
