egr question
Old Jul 30, 2011 | 12:14 AM
  #16
Re: egr question
Plus as far as I know, EGR is there to control NOx at high combustion chamber temperatures, not "CH" (HC?)
Old Aug 5, 2011 | 07:45 PM
  #17
SlowMoComotion's Avatar
Re: egr question
If the egr solenoid is unplugged from its electrical connector does the computer still try to add timing or does it shut off the egr and have the same effect as tuning it out?
Old Aug 6, 2011 | 08:41 AM
  #18
NJ-LE's Avatar
Re: egr question
SlowMoComotion:
Good question! I believe the PCM will NOT add timing because it "thinks" there is an EGR equipment failure. It WILL store an EGR failure code. Your state auto inspection will count that code when it decides whether or not the car passes inspection. Short of reprogramming out the EGR function, just pulling the plug is the best way to eliminate EGR. (again; if a resistor is inserted in the plug then the PCM will "think" the EGR works and add timning)
Old Aug 6, 2011 | 10:26 AM
  #19
Re: egr question
Thank you for your quick response. In Tunerpro RT under the flags section i disabled the egr electrical failure error, and egr diagnostic error so i do not get a SES light on my dash. I still have the connector to the solenoid unplugged. I figured this was a band-aid solution so I can get driving until I learn how to properly tune it out.
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
