EGR Question
Old Dec 24, 2003 | 02:21 PM
1FstFormulaV8's Avatar
EGR Question
Is there any electrical wire in the vacuum line what so ever? Because I disconnected my line and put a screw in it to plug the line. And now, the car won't start up. I think the battery may also be dieing. Whenever I turn it the key I'm getting a crazy clicking sound. Could the screw have messed anything up? It was a button head, I put it in as for as it would go, I took it out and tried to start it...again, crazy clicking sound.
Old Dec 24, 2003 | 03:59 PM
jchevy's Avatar
Sounds like the battery is dead, is the clicking coming from the starter. Try jump starting it.
Old Dec 24, 2003 | 04:27 PM
S.J.S.'s Avatar
How are all the lights on the dash when turn the key on?????
Old Dec 24, 2003 | 04:30 PM
Eliminator's Avatar
I would say dead battery no electric wire in vac. line.
Old Dec 24, 2003 | 05:46 PM
HBHRacing's Avatar
the vac line at the valve connects to the EVR selinoid witch has an electrical connection. but either way that will not cause your no start. the starter does not have enouh power.. check your battery
Old Dec 24, 2003 | 06:58 PM
It was the battery. I jumped it with my Camry. I have another problem though. For a while now my cooling fans will not turn off! They are on constantly even when I have accessory on. I was thinking about wiring them on a seperate switch. Any Ideas?
Old Dec 24, 2003 | 07:02 PM
jchevy's Avatar
If you have an ses light it will somtimes automatically turn the fans on.
Old Dec 24, 2003 | 11:40 PM
Fastbird93's Avatar
Anytime you set a DTC and the MIL (SES) comes on and stays on, the computer goes into a default mode and will automatically turn on the fans.
Old Dec 25, 2003 | 12:59 AM
No SES lights. How do I correct this problem?
Old Dec 25, 2003 | 01:05 AM
meengreen 94z's Avatar
Unplug your battery and reset the computer and see if it works. Having the fans run constant wont hurt anything. One of mine was rewired to run constantly before I bought it 3 years ago and works fine.
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
