EGR pipe bolt?? quick response please
Old Aug 29, 2004 | 08:23 AM
FireHawk409's Avatar
Im trying to find out what the size of the bolt where the egr pipe connects to the manifold or in my case headers. I lost it and need another one. I tried searching on shoebox's site but it listed the part number not the size. Im guessing this is the part number #10222897. It came off the exploded view of his site.
Omar
Old Aug 29, 2004 | 10:18 AM
Re: EGR pipe bolt?? quick response please
When I did a header install, the coating had plugged up the threads in the mount on the header tube, and I used a 5/16-18 tap to clean them out.
Old Aug 29, 2004 | 10:22 AM
indieaz's Avatar
I lost mine too, nobody seemed to know. Even at the GM dealer i had the guy look it up and he couldn't tell me the thread size...3/8ths and 10mm both wouldn't fit...threads weren't dirty at all. I could have tapped it if i wanted to take my headers out again. Instead i just put the pipe on and used a 5/16ths bolt with a nut on the other end to hold it on. Hopefully that lasts a while
Old Aug 29, 2004 | 10:51 AM
flusz28's Avatar
good luck finding some - but i used a 22mm bolt and it worked great for mine.
Old Aug 29, 2004 | 10:55 AM
thanks for the help guys. I dont have the pipe to put on i have a block off plate. That bolt and nut deal sounds like an idea. Ill just smear it with some locktite and it should hold.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
94Form
Feb 10, 2015 11:23 PM
thenewkid
Nov 18, 2014 12:57 PM
