Egr delete
Old Jan 17, 2008 | 09:51 PM
Bigrick2324's Avatar
Egr delete
I want to delete my egr and air i know what to take of my A.I.R but the egr has all the rubber hosing what do i do with all this stuff can some one help with maybe pics or details description
Thanxs guy you guys have been big help to me tonight
Old Jan 17, 2008 | 11:35 PM
EGR rubber hosing? Maybe your mean hosing on the AIR system? If you could provide the year of the car, someone could help you better. They are not all the same. The search is a good thing to use as well.
Old Jan 18, 2008 | 09:01 AM
Tell us the year of your car.... all year LT1's are not the same.
Old Aug 25, 2008 | 11:56 AM
97z2bgreat's Avatar
egr block off help!!!
i have a set of 95 z28 header im putting on my 97 z if i block a.i.r and egr is there any way to make it legal in mass because there is no egr hook up only a.i.r
Old Aug 25, 2008 | 01:27 PM
RUDEDOG's Avatar
Yes. Lose the air and egr. Get a good cat and tune.
Old Aug 25, 2008 | 06:33 PM
It will be illegal if the 95 headers are single-cat headers. Your 97 left the factory with 2 cats. You can not change the number or location. Whether your locality chooses to enforce that rule, or how closely they even check will determine whether you pass of fail. Additionally, IF they do a visual inspection, they are going to look for the CARB-EO tag on the headers, and for the AIR system.
Not clear exactly what you are actually doing with the AIR, since in one place you said "if i block a.i.r" and in another you indicate "there is no egr hook up only a.i.r". Are you leaving the AIR pump in place, and all the tubes, check valves and connections to the headers, then blocking the air flow? Not sure why you would do that, since the AIR system does not hurt performance in any way.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
