egr block off question
Old Feb 28, 2003 | 10:51 AM
  #16
anaik's Avatar
Originally posted by Blk94Z28LT1
i still don't see how introducing hot exhaust gas into the combustion chamber lowers the temp.
Here is an explanation.
http://www.ws6zxr.com/showthread.php...nitrous+oxides
Old Feb 28, 2003 | 01:24 PM
  #17
97_TA_WS6's Avatar
Question
So, is blocking off the EGR and getting the program erased from the computer a bad thing to do??
Adam 1997 Trans Am WS6 M6 has Borla cat back,LT4 knock module,subframes,Hypertech PP+,Hypertech 160 Thermostat,Air foil,Mac Pulley,K&N filter,B&M Ripper Shifter,MSD 8.5MM wires,Energy Suspension Trans mount & Torque Mount,1LE Driveshaft,MBA Silver Shift **** with WS6 ingraved on it,SLP 21mm Rear Sway bar,Viper GTS-R Carbon Kevlar syncros in a rebuilt T-56, Throttle Body Bypass, SLP pressure plate/clutch and a Hotchkis Strut Tower Brace.
Dallas, TX
Old Feb 28, 2003 | 03:13 PM
  #18
anaik's Avatar
The LT4 cam had a LSA of 115 and didn't require the EGR. My cam has a 112, and without an EGR I pass a roller smog test easily. So, I would say, with a stock cam, 117 LSA, to delete it would be a mild hinderance to normal driving. Probably couldn't pass smog if you had to, just guessing.
I have custom programming and cats.
Old Feb 28, 2003 | 06:46 PM
  #19
Janny's Avatar
If you look at the tube and the port on the back of the manifold, you will find that the orifice is just about the same size as a dime. That is what I used to block mine off. Put a new gasket in coat it and the dime liberally with high temp RTV, and you will save your self a few bucks, and your car will be worth .10 more.
Old Feb 28, 2003 | 07:48 PM
  #20
Z95m6's Avatar
I reused all my old parts when taking off the egr. I took the valve off the back of the intake and cut a piece of house flashing off and siliconed it to the valve so it would block the valve off. I had to destroy the valve and just use the cast iron base of the valve. I then took the old EGR tube and cut it in half so i could get the fittings off of it and then welded the holes on the fitting shut and bolted them back on. 1 year later they are still good and it didn't cost me a dime.
Old Feb 28, 2003 | 09:11 PM
  #21
cals400ex's Avatar
i appreciate all of the replys. i really did not understand how it all works but after that article, i understand better. i still do have one question though. by how these posts sound, the car may run a bit warmer. i talked to someone with a 93 and he said that it ran quite cooler. with everyone that has done this mod, which is it? or does it run at about the same temp? thanks
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jocamino
Dec 29, 2014 10:15 PM
cmdeshon
Dec 27, 2014 10:06 AM
Catmaigne
Dec 25, 2014 12:16 PM
