EGR block off question
Old Mar 29, 2003 | 12:02 PM
Alan566's Avatar
I am in a rush so here is what i did. I took the flex line(from pass side header to intake) loose at the intake and dropped a quarter in front of the hole and then retighened the 2 bolts on intake. I used a little high temp copper silicone on both sides. If I just unplug the EGRs vacuum would that be the same as takeing it off and putting a plate on? I will make the plates next week or buy some if I can't get to it but I need to know whats best to do now. Thanks Alan
Old Mar 30, 2003 | 07:19 AM
my96z's Avatar
Cant answer your question but, dud the quarter thing work? No leaks? If so thats what I am going to do. I have the LT4 block off plate now I just need to plug the other hole, and if I only have to spend .25 thats cool.
Thanks,
Jeff
Old Mar 30, 2003 | 08:02 AM
As long as the EGR is sealing and you remove the vacuum line so it cannot open, it should be as effective as a block off plate. Make sure you plug that vacuum off at the source, so you don't have a vacuum leak.
Old Mar 30, 2003 | 08:57 AM
Wildwill532's Avatar
im still confused which part gets takin off and blocked is it just the stainless stell small metal EGR pipe to exhaust manifold like in shoebox's pic or something else too
Old Mar 30, 2003 | 09:11 AM
1QUIKTA's Avatar
Here is a link for the plates and Steve will give you all the tech assistance you need.
http://www.mycamaroz28.homestead.com/
Old Mar 30, 2003 | 09:17 AM
T/A#4's Avatar
Thumbs down
OF COURSE YOU KNOW THAT BY DOING THIS YOU THROW THE COMPUTER OUT OF WACK ?
Old Mar 30, 2003 | 09:21 AM
It won't "throw it out of whack", but on your 1997, it will most likely cause a trouble code unless you have the pcm reprogrammed to ignore it or use some method to trick the pcm.
Old Mar 30, 2003 | 09:57 AM
i know how to do it for the pipe the runs to the exhaust manifold ill but it and roll/fold really tight with a vice and put some high temp rvt sealent around it, but is that the only one i need to remove to install hooker lt's
Old Mar 30, 2003 | 10:56 AM
Alan566's Avatar
I am running obd1 right now. its already been programed out of the pcm. So as long as I plug the vacuum line going to the egr and I block off the exhast gas from entering the intake it should be fine. right? I just didn't know about the egr if it had to removed or what. Thanks Alan
Old Mar 30, 2003 | 12:09 PM
just say what all needs to be blocked
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jocamino
Dec 29, 2014 10:15 PM
cmdeshon
Dec 27, 2014 10:06 AM
Catmaigne
Dec 25, 2014 12:16 PM
