EGR and AIR PUMP????
Old Mar 6, 2004 | 03:13 PM
Hershball's Avatar
How does one turn these off without setting off a seris of check engine lights??? What do you need to take these off and make the engine run right and what kind of power increse do you get???
Old Mar 6, 2004 | 03:22 PM
FacelessZ's Avatar
no power increase...5-8lb lost after the removal of the air pump is all youll see...
taking out the air pump is very hard unless youre doing a cam swap or something...it can simply be unplugged...
the egr just needs to be blocked off in the back of the intake...
if you decide to delete both of these, youll want to program them out of your pcm...
Old Mar 6, 2004 | 03:24 PM
Red96Lt1's Avatar
No power increase. It doesn't work under WOT. As far as codes, I think if it's OBD I it won't set a code.
Old Mar 6, 2004 | 03:33 PM
Hershball's Avatar
I have a 95 z28, i'm doing a cam swap and adding headers along with the cam. What do i need to do to shut off the air pump and EGR??
Old Mar 7, 2004 | 11:41 PM
In your OBD-I 95, all you need to do is unplug the AIR pump, making sure there is a good fuse in the circuit. You will not get an SES light or a code if the fuse is OK.
On the EGR, IN GENERAL OBD-I will not set a code for a missing EGR valve. BUT IT IS POSSIBLE... I'd say a 5% chance that you will get a code. If you get the code, you will need to program.
But as noted, no power gain, and in giving up the EGR you will actually be losing some protection against detonation when lugging the engine in too high a gear - a side benefit of the eGR system.
HectorM52
Jul 30, 2017 11:46 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
