EGR and AIR block off?
This weekend Im going to be installing my Jet Hot LT's and wont be keeping the EGR or AIR. I know i will need some block offs for this but what exactly do i need?
For EGR you may need these : http://www.mycamaroz28.homestead.com/
i may be wrong,,,but
blocking the egr stops the hot air from the headers from being pulled into the intake right?
i heard from a technician that although the air from the headers is very hot,,its cooler than the air inside your cylinders, which is the egr's purpose right? to cool down the air in your cylinders? thats why i didn't block mine off, its on there for a reason.
The EGR system is used to lower NOx (oxides of nitrogen) emissions caused by high combustion temperature and excessive oxygen. Adding exhaust gas displaces oxygen and decreases combustion temps. It does provide some cooling effect, but not in the typical way.
stockssn2o
May 25, 2015 08:54 AM
95chwagon
Jan 13, 2015 09:19 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
