egr
Old Jan 17, 2005 | 10:31 PM
Daniel6718's Avatar
egr
ok so i have the intake off my 94 z28 and im blocking the egr...i blocked off the hole in the intake for it but what do yall guys do with the censor that plugs into it??? do yall leave the egr valve on it with the blockoff plate under it
Daniel
Old Jan 17, 2005 | 10:49 PM
camarokid24's Avatar
Re: egr
Why are you blocking it off ? I blocked mine off becuase I couldn't hook it up to my headers (bad fitment issues) I only blocked off the EGR tube that goes to the manifold , I left the EGR solenoid on the intake ,unhooked the vacuum line to the manifold and caped both. I also left the solenoid plugged in because it gave me an ses light unplugged.
Old Jan 18, 2005 | 12:21 AM
Bawls's Avatar
Re: egr
Daniel
You can remove the solenoid man. Just un plug it and pull it. Your pcm will throw a faulty EGR solenoid code till you get it programmed out.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
