egr?
Old May 28, 2004 | 09:18 PM
kyzar24's Avatar
egr?
when you get rid of the egr valve and everything what do you do with the little black vacuum box or whatever it is i know u block off th intake vacuum but what you do with the little black box that the sensor plugs in
Old May 29, 2004 | 02:42 PM
cmking26's Avatar
If your talking about the plug on the drivers side rear of intake with 2 vacuum lines running into it, I just blocked off (plugged) the line where it connected to egr and then put it back on so I could hook up the electrical connector to it.
Old May 29, 2004 | 03:58 PM
kyzar24's Avatar
thats the one no problems doing that?
Old May 29, 2004 | 04:56 PM
cmking26's Avatar
If you have OBD1 computer you shouldnt get any codes. Make sure theres a good seal i.e no vacuum leak. OBD2 might get SES light.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
