Edelbrock Lt1 Heads
Old Feb 5, 2003 | 12:31 PM
964MLA's Avatar
Edelbrock Lt1 Heads
Edelbrock will soon have availible LT1 heads for the 92-97 LT1's. They have 1.94 in 1.55 ex valves, 170cc intake & 60cc exhaust ports, 54cc combustion chamber & made 24 more hp on a stock motor. Also the peal power level was raised by 500 rpm. Hopefully these heads peform as good as they claim. If anyone need more info please ask
Old Feb 5, 2003 | 12:45 PM
rasilverbird's Avatar
Price???
Old Feb 5, 2003 | 01:08 PM
964MLA's Avatar
price not availible yet. when i find out the price i will post it
Old Feb 5, 2003 | 01:20 PM
Dr.Mudge's Avatar
Doesn't sound too exciting honestly, unless they somehow have potential to flow big numbers while not touching the intake runner. Sounds like stock heads with some bowl porting and a half decent valve job.
At least they are doing something though, I spose
Old Feb 5, 2003 | 02:51 PM
964MLA's Avatar
here are the flow #'s:
.100 61in 52ex
.200 117in 100ex
.300 174in 140ex
.400 220in 167ex
.500 242in 184ex
.600 232in 192ex
these measurements are @28" h20
i am not sure what a stock head flows but i am sure it is not near these #'s. dr mudge are we a little pesimistic? i doubt they are bowl worked/valve jobbed stock heads. why would they do that? it makes no sense.
Old Feb 5, 2003 | 03:49 PM
Ai's Avatar
Ai
So may we assume you work for Edelbrock or are a reseller?
Those exhausts are without any sort of pipe/extension? SF-600? 4-4.060 bore or so I assume?
That really isn't any better than a cleaned up stock head... and the cleaned up stock head would have a better E/I ratio. Like mudge said.. not too exciting. If they're like Edelbrock's ford stuff however, they've got plenty of material for someone who knows what they're doing to get nice #'s out of them
Old Feb 5, 2003 | 04:50 PM
Dr.Mudge's Avatar
I'm not trying to say they scoured junkyards in 48 states to find LT1 heads, and cleaned them up, my point is that is thats what they flow like. Nothing too spectacular to look forward too from what I can tell, of course there could be a ton of material there to remove but no real way to know that without seeing the heads.
Those heads flow about like LT4s, not much better than stock. If they are under LT4 price, and have 300+ CFM potential, then there may be a reason to be interested, if they will sell them bare
Old Feb 5, 2003 | 05:23 PM
n2ceptor's Avatar
http://web.camaross.com/forums/showt...delbrock+heads
This was posted in the lt1 tech...
Old Feb 5, 2003 | 05:26 PM
Mindgame's Avatar
A little "pesimistic"? Yeah, maybe.
I remember when the Turbo 292 small block Chevy heads were it. Everyone was using them and every porter on the planet knew how to get big power from them. Well.... along comes Brodix, Brownfield and a few other head builders with their new and "improved" stuff.
Believe it or not, but it took a while before people started figuring out that these heads had more potential than the ol 292's. It wasn't just flow numbers either. Hell, I've seen heads that flow 5% less than another head and make more power! How is that... well it just goes to show that there's a little more to a cylinder head than how much flow it has at a given lift. Most of the advances in the old days and up til now have come from better combustion chambers, spark plug positioning, squish pad positioning, swirl, bowl depth etc., so let's just wait to see what the little Edelbrock heads can do before casting any stones. Might be surprised and we may not.
-Mindgame
Old Feb 5, 2003 | 05:36 PM
964MLA's Avatar
part # 61919 bare
part # 61909 complete
dr mudge:i do not know of any aftermarket head that cannot be ported. it does not exist. 300 cfm potential i do not know if possible but my guess would be yes.
skarodom: sf 600 ya right, they have a sf 1020 best of the best
mindgame: you hit the nail on the head. flow #'s are not everything. anyway a pair of heads could by flowed on 2 different flow benches & get 2 different readings
Old Feb 5, 2003 | 08:37 PM
OneFlyn95z28's Avatar
I think it is nice to have a good stock replacement
I mean hell they have not made a LT1 since 97! They COULD do like most others and just turn there back on us
Old Feb 5, 2003 | 09:25 PM
Moving to LT1 Tech.... please follow guidelines.
Old Feb 5, 2003 | 09:45 PM
Dr.Mudge's Avatar
Just as any stock head I can think of can be ported, including a lawn mower flat head, not sure what your point is.
Old Feb 5, 2003 | 10:09 PM
bunker's Avatar
Heck the compression in these heads alone makes the 20+HP difference I guess the extra flow isn't doing much.
Old Feb 5, 2003 | 10:15 PM
Dr.Mudge's Avatar
Compression might be 8-10 of it, who knows. Unless the combustion chamber is somehow more efficient, maybe even a different plug location, who knows.
It would be nice to see, and sure, this could be a great head with some work, but need to see prices and pictures to make better guesses
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
