ED Timing chain. How many miles on it and how many issues?
Old Aug 21, 2005 | 08:40 PM
Steves396lt1
Guest
Posts: n/a
It seems there is a hit and miss with the ED timing chain. SOme love it or some have them break on the water pump gear. I am curious how many miles everyone has with it and/or any breakeage with it?
Old Aug 21, 2005 | 09:01 PM
1racerdude's Avatar
Re: ED Timing chain. How many miles on it and how many issues?
Some of the problem is not changing the little WP gear.Another problem is that an LT-1 has a very small hole in the both front lifter galley plug's to lube the gear and chain. When the engine is rebuilt they put SBC plug's in there that have no holes and the gear get's NO lube.So most of the problems are assembly related and not the fault of the timing set.
Old Aug 21, 2005 | 09:02 PM
Steves396lt1
Guest
Posts: n/a
INteresting. I did notice the two plugs up there. They didnt look very big, but looked identical to the plugs in the "how to Build a LT1/4 motor"
Old Aug 21, 2005 | 09:16 PM
1racerdude's Avatar
They are about the size of a dime and are pretty close to the outer diameter of the cam sprocket(one on each side). and should have 1 hole each about the size of a sewing needle in them.If they don't change them.
Old Aug 21, 2005 | 09:46 PM
Steves396lt1
Guest
Posts: n/a
They had little holes in them. SO they should be good.
Old Aug 21, 2005 | 09:55 PM
1racerdude's Avatar
OK ya are good to go.
Old Aug 22, 2005 | 12:17 PM
Steves396lt1
Guest
Posts: n/a
ttt
Old Aug 22, 2005 | 03:58 PM
joeSS97's Avatar
30K so far...I am sure it will go alot further.It is real quiet too.I would recommend it.
Old Aug 22, 2005 | 05:36 PM
Z95m6's Avatar
I have about 30k and i just had my timing cover off just this summer and no stretching or wear.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
