ECT sensor help needed
Old May 12, 2005 | 07:56 PM
94lt1redta's Avatar
In some freak incindent, my ECT sensor for the gauge broke and the plug got pulled from the wires. I got a new sensor and I'm wondering how many wires go to it. The sensor has 2 metal prongs on the sensor but there is only 1 wire left (is there supposed to be 2 wires?) If it is only 1 wire going to the sensor, which metal prong should i hook it to? Thanks for all help
Old May 12, 2005 | 09:41 PM
Re: ECT sensor help needed
The gauge sensor only has one wire and the sensor should only have one prong (as I recall).
Old May 12, 2005 | 11:06 PM
slowpoke96z28's Avatar
do you have a multimeter? have you installed the sender? As shoebox sais, it should only hsave one terminal. if there are two, they should be marked "A" and "B". According to the schematic, pin "A" should be connected to the wire. if its not installed, ohm out both pins with respect to the sender's body, if they both have the same resistance, then it doesn't matter.
Old May 13, 2005 | 12:51 PM
Are you sure you bought the correct replacment sensor? The one in the head has a single pin. The one for the PCM in the water pump housing has two pins. Sounds like they gave you the wrong one.
Old May 13, 2005 | 02:36 PM
you need to ask for a water temp gauge sender, not a ECT sensor, when you go to the parts store.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
