ECM question
Old Jan 9, 2004 | 01:21 PM
RE AND CHERYL's Avatar
Cool ECM question
I have a 94 Z with the soldered in ECM chip. I'm just courious if it's interchangable with the 93 ECM with the replaceable chip. I'm doing a head/cam swap this winter and would rather just have a chip burned than send in the whole ECM to have it reprogramed.
Old Jan 9, 2004 | 01:29 PM
gb95zconv's Avatar
Not interchangable.....94 pcm chips have to be flashed. You can send your pcm out to have this done or buy Tunercat /LT1edit software and a cable with a converter and do it yourself with a laptop.
Old Jan 9, 2004 | 01:42 PM
Cool
OK...Maybe I didn't make it clear. I want to swap the entire EMC for a unit with the removable chip. Can I do this???
Old Jan 9, 2004 | 02:25 PM
LeeS's Avatar
No! The reason is that the 1993 car is set up on Speed Density System meaning it doesn't have a Mass Airflow Sensor and your 1994 Has a Mass Air flow sensor.
They wiring Harnesses will not match either.
Have a goodone Lee!
Old Jan 9, 2004 | 02:27 PM
gb95zconv's Avatar
No.....at least it wouldnt be a plug and play swap. It may be possible, maybe someone else will chime in.
Old Jan 9, 2004 | 03:13 PM
OPS...Forgot about the speed density thing. How about the early 95s, before the switch to OBD II
Old Jan 9, 2004 | 03:28 PM
gb95zconv's Avatar
94-95 pcm are interchangable but must be flash tuned to match your car.
warmeck
Jan 20, 2015 09:20 PM
97SSdude
Dec 31, 2014 07:43 PM
4586
Dec 31, 2014 02:21 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
