Easy Rebuild Question...Shoebox?
Old May 8, 2003 | 08:59 PM
scyzoryk's Avatar
Easy Engine Rebuild Question...Shoebox?
Do I need to rebalance my engine assembly if I use lighter pistons (Hypereutectic Speed Pro Pistons)? I heard that is pistons are 10% lighter I have to do that. Is this true? I am changing pistons/rings/bearings/hot Cam kit/timing chain set...
ps .What is the best method to instal valvel steam seals?
Old May 8, 2003 | 10:13 PM
scyzoryk's Avatar
ttt
Old May 8, 2003 | 10:24 PM
AFAIK, balancing is not mandatory at any time.
Some other advice-You might want to try to observe forum rules of one TTT per 24 hours. Posts that get TTT'd a lot by the author tend to get less posts instead of more.
I also think that you cause limited responses to posts by sticking a person's name on it (like mine ). There are plenty of competent board patrons, some being well versed in certain areas (ex. engine building).
Old May 8, 2003 | 10:38 PM
scyzoryk's Avatar
But you are the best .....I know I wasnt suposed to do ttt so quickly, but I am starning my rebuild tomorrow morning and I neeed that info...
Old May 8, 2003 | 11:34 PM
rskrause's Avatar
Moderator
I would have the rotating assembly rebalanced.
Shoebox is correct - I didn't read this thread at first because it was addressed to him. Then I did get curious.
Rich Krause
Old May 8, 2003 | 11:38 PM
scyzoryk's Avatar
What is the cost of doing that. Do you know any good place in NYc that do that job?
Old May 8, 2003 | 11:56 PM
rskrause's Avatar
Moderator
Sorry, not in the NYC area. It shouldn't be too expensive, because you have gone to lighter pistons. It's more difficult to add weight which requires the use of expensive "mallory metal". Maybe $75-100 or so.
Rich Krause
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 29, 2015 03:18 PM
