is it easy to change injectors on a 93 LT1? also - would 24# from a 94 work in a 93?
Old May 23, 2004 | 04:20 PM
sc93's Avatar
I found a set of used 24 lb injectors for sale from a 94 LT1, and I was thinkin of getting them for my 93 since they are 22lb stock, as a little upgrade for my cam.
Is it easy once I unbolt the fuel rail and disconnect the fuel lines?
Old May 23, 2004 | 05:49 PM
Fastbird93's Avatar
In answer to your questions, yes and yes. Swapping Injectors is easy. Just be careful to spill as little fuel as possible, and depressurize the system before swapping.
Of note, the 94 Injectors are 2lb greater than the stock 93's (duh) and as such you will need to get a tune for your car with new injector constants set, or you're going to be running rich.
Old May 24, 2004 | 12:06 AM
sc93's Avatar
Cool,
yeah Alvin at pcmforless did my tuning for the cam, I'd just have a new chip done for the bigger injectors.
Do you think the 24's would be good enough for awhile for my 227/233 on stock heads??
Old May 24, 2004 | 04:58 AM
Fastbird93's Avatar
Yeah, they should be good.
Old May 24, 2004 | 08:47 AM
cmking26's Avatar
If interested I have a stock set of 24lb injectors from my 94 TA with 48,000mi. Or I have a brand new set of Bosch style 25lb injectors that I installed and drove for maybe 15miles to make sure they worked. I did more mods so I ended up getting 30lb injectors. If interested shoot me an email.
mr28
Apr 20, 2016 05:44 PM
birdblack
Dec 30, 2014 06:59 PM
siguy
Nov 27, 2014 10:07 AM
mr28
Nov 23, 2014 11:11 AM
Jul 4, 2005 05:00 PM
