easiest way to remove steering linkage?
Old Jul 12, 2003 | 02:47 PM
got_hp?'s Avatar
ok.......the bottom bolt, and top bolt are removed and the linkage is loose............but it wont slide out from either end
is there a trick to this, or do you just have to yank the thing out with force? i would try turning the wheel, but its on ramps so i cant.
Old Jul 12, 2003 | 03:34 PM
Fastbird93's Avatar
I just took a rubber mallet and tapped it out. It should come out pretty easily if I remember right.
Old Jul 12, 2003 | 03:47 PM
turbo_Z's Avatar
i used a pry bar and it slid off pretty easy.. getting it back on is where things got tricky for me.
Old Jul 12, 2003 | 03:53 PM
revtime's Avatar
Same here, I pryed it off the top mounting location and after the header was in I pryed it back on.
Prying it back on can get a little tricky, you have to get the right angle on it, took me about 15 to 20 minutes to get the angle just right to pop it back on.
Victor Lamb
Aug 26, 2017 02:52 PM
CheckOutMyRoost
May 23, 2015 02:33 PM
Apr 16, 2015 09:57 AM
