Easiest Way To Remove Spark Plugs With Pacesetter Lt??
Old Sep 11, 2006 | 05:20 PM
playa7970's Avatar
Question Easiest Way To Remove Spark Plugs With Pacesetter Lt??
i wanna know how the hell you guys do it in detail pleaseeee i have most of the tools but the deep socket i have for spark plugs is too long and hits the headers looks almost impossible to do any tips thanks
Old Sep 11, 2006 | 05:54 PM
Severous01's Avatar
Re: Easiest Way To Remove Spark Plugs With Pacesetter Lt??
take a normal plug socket and cut about 1" off the end. cut the rubber insert in half and put it back in. use a ratchet wrench for the rear cyls and a normal socket for the others. all can be accessed from under the car with the short socket if you have a lift.
takes me about 25 minutes with the lift
Old Sep 11, 2006 | 06:00 PM
playa7970's Avatar
sorry for bein so dum but what do you use to cut it an inch down and what rubber insert?
Old Sep 11, 2006 | 06:28 PM
LT1_383's Avatar
I use an offset 5/8" wrench for all of them. Most are easly accessable from the bottom. Don't even have to remove the alternator like with manifolds. If you don't have the AIR fittings it's a lot easier as well.
You could use a cut off wheel to make quick work of cutting down the socket, or a hacksaw if you don't have access to a cut off wheel. The rubber peice he was refering to was the rubber part of the spark plug socket, it's inside and holds the spark plug in place so it's easier to start when it's in the socket.
Old Sep 11, 2006 | 06:33 PM
95LT1conv's Avatar
i can get all 8 from the top in about a half hour w/ pacesetters
Old Sep 11, 2006 | 06:47 PM
lt11997's Avatar
Here is a picture of a modified spark plug socket http://www.slponline.com/view_produc...02&BIG=30102-1.
You can save yourself $20 buy going to a parts store and buying a $5 socket and cutting a inch off like somebody above said. I made one myself and works real good, I even use it on cars at work sometimes.
Old Sep 11, 2006 | 07:50 PM
GMRL's Avatar
What he said
Also I use a 3/4" gear wrench on a spark plug socket, a combo of both of these methods shouldnt take you any more than an hour max to get all 8 of them.
Old Sep 11, 2006 | 08:00 PM
Drowned's Avatar
Same here... I love my pacesetters... I use normal tools, no modified sockets...
Old Sep 11, 2006 | 08:13 PM
playa7970's Avatar
thanks again guys
Old Sep 13, 2006 | 09:28 AM
2000GTP's Avatar
I will just push the plug socket over the plug then I will get a stubby open end wrench and take them out that way. Works for every cylinder.
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
