96 Pcm Wire Pinout Help
Old Sep 13, 2006 | 08:43 AM
LT1_S10's Avatar
I need the 96 wire pinout for the PCM i am trying to wire in the OBD2 connector so i can put the car on the scanner so i need to trace the wires to where they go if anyone can help with were the wires go thats great
Old Sep 13, 2006 | 09:43 AM
madwolf's Avatar
Re: 96 Pcm Wire Pinout Help
From Shoebox's website: 94-97 PCM Pinouts
Old Sep 13, 2006 | 09:55 AM
LT1_S10's Avatar
I used that and it is comming up with a "link error"
Do you know exactly what wire goes where?
This is the way i have it hooked up right now
wire 2 on the dlc connector is hooked to D7
wire 4 on the dlc connector is hooked to B16
wire 6 on the dlc connector is hooked to D20
wire 8 on the dlc connector is hooked to C32
wire 9 on the dlc connector is hooked to D30
wire 16 on the dlc connector is hooked to B31
Is this right?
jayvar
Feb 2, 2015 10:00 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
