Easiest way to intsall L/Ts on a LT1
Old Jun 21, 2006 | 10:33 AM
White95LT1's Avatar
was just wondering what the easiest way to install L/T headers on a LT1 would be.. I have the tranny out with it getting re-built.....and I don't exactly want to drop the motor...so any info would be great.....Pretty sure this seems like a pretty dumb question to most...plz forgive the stupidity on my half
Old Jun 21, 2006 | 11:43 AM
fast96lt4's Avatar
Re: Easiest way to intsall L/Ts on a LT1
easy if you have a lift. Otherwise jack stands will do but you will consume more time. I have done 3 installs with jack stands. 2 times i had to loosed the motor mount and jack up about 6 inches. It is fairly easy though just takes patience and beer. I have done 2 out of 3 installs by my self. Not as hard as it seems. I had more trouble with my old BBK shorty headers...
Old Jun 21, 2006 | 11:48 AM
95z28man's Avatar
Unless you are at least PREPARED to lift the motor, I would take it to a shop. The drivers side will go in if you remove all the proper parts. The passenger side MAY go in but probably not. Some claim they didn't have to do anything special to get it in, but with my own experience, I had to tow it to a shop and I believe they had to lift the motor on the passenger side and slip in. Not a small job at all. If you plan on doing it at your house or something, I hope you have all the proper tools and some experience.
Old Jun 21, 2006 | 11:54 AM
camarolover20's Avatar
Its not that hard but takes time!!
Old Jun 21, 2006 | 02:04 PM
luckyou03's Avatar
i have my jack stands on 4 inches of wood and all the way up. Both pacesetter went in threw the bottom no problem.
Old Jun 21, 2006 | 02:41 PM
69z-28's Avatar
easiest way....
take it to a shop.hehe
Old Jun 21, 2006 | 02:51 PM
2QUIK6's Avatar
If you took the tranny out on your own, you should have no problem getting the headers in. The passenger side is the trickiest.
Get car up as high as you can, or on a lift. With tranny out it should be a snap. Remove the altenator and the motor mount bolts. You will have to jack the motor up on each side to give you more room.
On the pass side, the tricky part was getting the front header flange around the AC tubes that wrap around up front. Also remove the starter, should be no prob.
Old Jun 21, 2006 | 05:30 PM
2000GTP's Avatar
Its not an overly difficult job and can be done with jackstands and a floorjack. My best advice would be to soak all of the old hardware very well with PB Blaster, that will make disassembly a breeze.
Old Jun 21, 2006 | 06:07 PM
MTBeni's Avatar
I didnt have to pull the alternator. I did mine on a lift no base, both went in through the bottom. I didnt have to jack the motor up much, mostly on the passenger side as stated already. I pulled the steering linkage to get the driver's side in. Its not that hard of a job, just frustrating and time consuming. It took longer to get the stock crap off though. BTW, put new motor mounts in while you have the headers out of the way. I didnt do it since my car had low miles and 6 months later swapped them out. What a pain in the *** doing it with the headers in!
Old Jun 21, 2006 | 09:15 PM
OrbitalChris's Avatar
jack it up, if you can use a lift like they said above^^ and you dont need to lift the engine out of anything, just be prepared to spend aboot 9 hours on it if youre not familiar with it good luck
Old Jun 21, 2006 | 09:36 PM
quick98's Avatar
I just ordered my pacesetter LT's today. I will have a K-member going in at the same time though so I don't think I will have many problems
Old Jun 22, 2006 | 01:00 AM
that sounds like a fun job I would goahead and do atleast a intake gasket why the motor is out for the K-frame!!K-frames arent so fun u will be spendin a good bit more time then any header install!!
Old Jun 25, 2006 | 02:02 PM
White95LT1's Avatar
Ok...well I have the Drivers side in and bolted up...The Passanger side is being a little bit more tricky.....I have noticed that with the Tranny being out it provided alot of working room, but also the degree the motor is tilted at just wasn't working cause the header was hitting the K-Member and preventing me from getting it in at the right angle to bolt it in place....but problem solved, it's In, just needs to be tightend up and it's good to go....can honestly say I would much rather do it agian if the Motor is actually out of the car next time
Old Jun 25, 2006 | 11:07 PM
White95LT1's Avatar
Completely done!...no unbolting of the motor, just pure pain in the *** work.....but it's done
BPS
9
Mar 5, 2015 10:51 PM
Renegade Toker
Jan 23, 2015 10:27 PM
artic94
Jan 17, 2015 11:19 AM
limige
Sep 14, 2002 08:18 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
