easiest way to change oil pump
Took a little shortcut in modifiying my car-didn't replace the oil pan gasket after the cam change. Just bought a new gasket and cut a piece out of it that goes around the timing chain cover. Now I found out that the shortcut didn't work-my oil pan gasket is leaking. Maybe you guys can tell me what's the easiest way for changing the oil pan gasket and oil pump. Do I need to take the engine out, or I can just jack it up a bit.
Thanks for replys,
Tomas
Thanks for replys,
Tomas
Jul 4, 2005 05:00 PM
