Easiest way for #8 cylinder wire???
Old May 27, 2003 | 08:03 PM
drewstealth's Avatar
My #1 and #8 cylinder was misfireing. I had a extra set of wires and a few extra plugs. So i fixed the #1 cylinder by re-routing the wire and putting a new plug in it. The plug was brand new but it was gapped at 55(the shop i took it to did a ****ty job). I left the old wire on it since it was only 2 weeks old. It seems like i fixed that cylinder misfire. But what is the easiest way to do the #8 cylinder. What should i remove? Is it easier to do it from the top or the bottom. Any help would be appreciated. Thanks.
Old May 27, 2003 | 11:19 PM
Anybody?
Old May 27, 2003 | 11:25 PM
atljar's Avatar
from underneath the car. Depends on your exhaust set up, but dropping the starter is easy (2 bolts, 14mm i think) and just tie it up and out of the way.
If that doesnt give you the clearance might drop the y pipe out of the way.
Old May 28, 2003 | 12:45 AM
Wild1's Avatar
The #8 is secured to the engine block by a stamped metal brace. There are two fasteners holding the brace to the engine block. I'd recommend disconnecting the battery to prevent any incidental sparks. Remember to use a safety stand to secure the jack.
I popped off the #8 from the plug, then I disconnected the fasteners. After that, just uplug from the opti and your set. I decided to buy some plastic wire looming to avoid any incidental chaffing... replacement wires are always a different length.
Old May 28, 2003 | 12:51 AM
Did you remove your starter and the y-pipe?
Old May 28, 2003 | 01:23 AM
atljar's Avatar
Been awhile since i did it with just the manifolds on there. I think i just had to drop the y pipe. Once i got headers i just have to drop the starter.
Old May 28, 2003 | 07:44 AM
anasazi's Avatar
drivers side wires were all easy as cake, very simple to do
for passenger side wires make a 90 degree turn just after they come off the opti torwards the back of the car, suddenly you have plenty of room for all plugs and nothing to burn on.
Old May 28, 2003 | 11:57 AM
Wild1's Avatar
No, I've got Edelbrock TES headers. No need to drop the starter or Y-Pipe. Just get the car in the air with some safety stands, you'll be fine. Don't forget about the metal brace...
Old May 28, 2003 | 12:53 PM
97ss150's Avatar
i did mine from the top. used a spark plug socket and a stubby 11/16 ratchet wrench. wasnt easy but it did happen and dont say only people with small arms can do it because my arms are big
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
siguy
Nov 27, 2014 10:07 AM
