View Poll Results: which shorty headers are the easiest to install?
Hooker shortys
0%
Macs(mids)
11
68.75%
Eldebrock
12.50%
BBKs
12.50%
SLPs
6.25%
AS+M(mids)
0%
Voters: 16. You may not vote on this poll
easiest shorty headers to install
Old Apr 6, 2003 | 12:31 PM
pickerman's Avatar
I know I ask alot of header questions,but, gonna be buying shorty headers soon. My brother in law and I are putting them in.I need input on your shorty header installs. from hardest to easiest. These are for my 93z.I havent done headers since when I put them on my 69 Camaro(28 years ago!).Whole different ballgame today Pickerman
Old Apr 6, 2003 | 06:05 PM
94F1Z28's Avatar
I have MAC and they were easy to put on and have great plug access.I found the hardest part of the job was removing the stock manifolds and y-pipe,after they were off the headers were easy to install.
Old Apr 6, 2003 | 06:17 PM
Crazy8's Avatar
I just installed mac headers this weekend with a couple of buddies and they were a b!@tch to do. If I didnt have my friends dad helping we would have never got done. I will NEVER do it again. Its possible though to get them in, just make sure you know what you are getting in too.
Old Apr 6, 2003 | 06:21 PM
94F1Z28's Avatar
Well i installed mine by myself,but mine are the single cat setup which i have heard are easier the the dual cats.
Old Apr 6, 2003 | 07:48 PM
Fast Caddie's Avatar
My MACs were a piece of cake to install. The hard part was taking the old manifolds off and fooling with that ****ing damn dipstick tube (2hrs by itself). That liitle POS had me about ready to drive up to GM headquarters and beat someone's a$$ for putting that thing on there. Especially on a newer engine.
Old Apr 6, 2003 | 07:52 PM
Crazy8's Avatar
i thought the easiest part was getting everything off. That only took about 4 hrs. Putting everything on was the hard part. Getting everything lined up and stuff. The dipstick was pretty easy to get out of my car. REAL easy to get back in. I guess it depends, i have never worked on a car besides putting a catback on and CAI.
Old Apr 8, 2003 | 11:33 PM
vogel18's Avatar
I hear JBA headers are the easiest to install mainly from sport shops even though they are not in your list.
Old Apr 8, 2003 | 11:59 PM
Z95m6's Avatar
definitely not slps they were a PITA but i think the 1 3/4 primaries made up for the hard install.
Old Apr 9, 2003 | 01:14 AM
Joe Gee's Avatar
I bought a set of edelbrocks a couple months ago. I got them used bout 8 months old for 150 with Y pipe. I heard you have to take out the steering shaft to get them in, is that true? I am ready to get them in? Hope it isn't too hard.
Joe
Old Apr 9, 2003 | 02:19 AM
chesee48's Avatar
i have the edel's and had no problems here.
From what i hear, MAC's have great plug access and everything..
Old Apr 9, 2003 | 04:45 PM
Joe Gee's Avatar
So you didn't have to pull out the steering shaft? How long did it take you to install them in the driveway?
Joe
Old Apr 9, 2003 | 05:08 PM
Prorac1's Avatar
I had to pull the steering shaft to install my bbk headers, and its not hard. Just dont turn the wheels or steering wheel and youll be fine. I tried to install without taking it out, and the header just dosent quite fit up in there. Heres another good one, i cant remember which side it was (its been a while) but one or both go in from the bottom. Good luck, prorac1
Old Apr 9, 2003 | 05:15 PM
mineralwater's Avatar
My MACs were easy to install, but the y-pipe didn't line up correctly. This seems to be pretty common, and if you bolt up the ypipe real tight before you tighten the headers, I think it'll be ok.
The best part of teh MACs is that for me, just using a standard spark plug socket at a 22mm wrench on the end of that socket, I can change all 8 plugs from the top in about 20 minutes.
They rock for plug access!
Old Apr 9, 2003 | 08:28 PM
ryker77's Avatar
I've purchased both edelbrocks and hookers. The edelbrocks look cheap when compared to the hookers.
The hookers do come with a y-pipe that y's into an oval flange. Which wouldn't be a problem if Jet Hot had sent the flange to me. The flange would make a perfect start to an 4"oval tube exhaust system.
I've not install either one.
With everyone saying this and that. It needs to be said who used a lift vice a single car jack. And who did this in the backyard vice a shop
I would think that with a lift, good tools and lighting that any header install would be easier. Yet in the backyard on a single jack - few beers - dawn sitting in well it would suck
Old Apr 9, 2003 | 08:36 PM
RicocheT's Avatar
JBA are my vote.. I hadn't installed any others but all I had to do was take an air grinder and reem out the bolt holes a little b/c of the ceramic coating and they fit fine.. Look good too
