Easiest header to install??
Old Apr 23, 2005 | 02:45 PM
snausman's Avatar
I'm ordering headers this weekend. Unless I hear something interesting in this thread I'm getting jet-hot long tubes. What is the easiest header to install?? no shorties.
They're going on my '96 ws6 TA, fyi.
Snausman
Old Apr 23, 2005 | 03:04 PM
MarkyMark's Avatar
Re: Easiest header to install??
Pacesetter are probably the easiest longtube to install, although I hear the Kooks headers have a really good fitment and are fairly easy to install as well.
Old Apr 23, 2005 | 03:09 PM
snausman's Avatar
Did you install your Pacesetters yourself? If so, could you outline any troubles you had/methods used? Anyone else???
Old Apr 23, 2005 | 03:23 PM
MarkyMark's Avatar
I pulled the starter, oil filter, valve covers, oil dipstick, alternator and disconnected the steering shaft coupler. I was able to put them both in from the top pretty easily. The hardest part for me was getting my old exhaust off.
Old Apr 23, 2005 | 04:03 PM
94TA25ann's Avatar
I did everyting he did on my Jet Hot install, but disconnecting the steering shaft and valve covers. The one thing I did he didn't have to do is unbolt one engine mount to jack up the motor on one side. I thought the Jet Hot's weren't all that hard.
Old Apr 23, 2005 | 04:04 PM
snausman's Avatar
I see you're going from 2.73 to 3.73 gears...you're going to f*****g loooove that.
Old Apr 23, 2005 | 04:16 PM
94TA25ann's Avatar
If I could get my damn car to run right I could drive it to the place who is going to install them for me. I should have my car running right by next weekend. My car came stock with 3.23's, but I think I should still see a huge difference between the two
Old Apr 23, 2005 | 05:02 PM
MarkyMark's Avatar
I am in the same predicament, I have open longtubes right now and I need to get the rest of my exhaust on and sealed up so I can drive to the place that is gonna install mine for me. My 2.73's are such dogs out of the hole, but they start pulling hard on the top end.
Old Apr 23, 2005 | 07:28 PM
bdc95ta's Avatar
I'm going to install a set of lt tpis's next week so I'll let you know. I think the hardest part is going to be getting off the stock manifolds.
-b
BPS
9
Mar 5, 2015 10:51 PM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
GigaMp3z
Feb 20, 2003 02:57 PM
