Earls stainless brake lines
I'm running these. A VAST improvement over stock. Well worth the price. This should be one of the first mods as the stock rubber lines suck. You won't be sorry running these, just make sure you flush the system and bleed properly.
Don't have them on my current Camaro, but I used to have them on an 69 Camaro I had. They made a huge difference in pedal feel. Much firmer and made the brakes a little touchy. I will eventually put them on my 94 I have now.
They also will last a lot longer!
i just did the c5 swap and i got the kit for the 5th gen vette and it worked fine. i was able to use the rear hoses in the kit on my car also by looping them around. there was no strain on the lines and the fittings matched up exactly. brake feel is a huge improvement.
kclarson
Aug 22, 2002 04:04 PM
