Eagle Competition Rotating Assemblies
Old Apr 9, 2006 | 09:55 AM
sleeperMULLET's Avatar
hey guys, i'm looking to build big HP with a 383 LT1. i'm unsure of what i shoudl do with the bottom end. i know lunati is good but thats out of my budget. will this Eagle Competition Rotating Assembly hold 600-700hp? http://store.summitracing.com/partde...5&autoview=sku
Anyone using this bottom end? Anyone have any suggestions, all advice is appreciated.
Old Apr 9, 2006 | 09:57 AM
97WS6NY's Avatar
Re: Eagle Competition Rotating Assemblies
YEs, it will hold 600-700 HP
Old Apr 9, 2006 | 10:02 AM
thanks for quick reply, how much power do you think it will hold?
Old Apr 9, 2006 | 12:10 PM
ajschult's Avatar
Its got a 4340 forged steel crank and rods, it will hold whatever power you throw at it. Check out cnc-motorsports.com you may find a better price.
Old Apr 9, 2006 | 12:22 PM
Honda Hunter's Avatar
I have that kit.
Old Apr 9, 2006 | 02:36 PM
FastZinTennessee's Avatar
Wow that's expensive! I paid $600 for a 4340 Eagle crank, $375 for the 4340 forged H-beam rods, and $575 for Mahle forged pistons/rings/pins. From what people have told me this setup should handle 800+ hp easy. I don't know for sure, but I know that it will take more than I will throw at it!
Old Apr 9, 2006 | 03:05 PM
Chopstix's Avatar
I am running the same crank(3.875 stroke) and rods in my 396 + a 300 shot
Old Apr 9, 2006 | 04:39 PM
Thanks guys, appreciate the info. i cant wait to build my engine now. I just got back from the track, I ran 3 13.4s with 103mph trap. I was spinning like crazy all through first too, my 60 foot was a consistant 2.1, if i would have hooked up better i think i could have done 13.1
Old Apr 9, 2006 | 10:44 PM
bdc95ta's Avatar
My engine builder told me eagle could balance better than any machine shop around. Can anyone confirm this?
-brandon
Old Apr 9, 2006 | 11:12 PM
97WS6NY's Avatar
I don't know first hand, but from what I have been told from machine shops i have dealt with, even if you buy the balanced assembly from eagle, you should have it checked because they are not always right on
Old Apr 10, 2006 | 09:24 AM
I agree with getting it re-checked.
Old Apr 10, 2006 | 02:20 PM
RealQuick's Avatar
If your going with turbo or supercharger, thos pistons have +16cc dome... = high compression. How do you plan on making 600-700hp?
Old Apr 10, 2006 | 04:29 PM
its going to be a 383, TFS 210cc heads from Advanced Induction, ported intake from A/I, 58mm TB, full aeromotive fuel system, 42lb injectors, complete MSD ignition, i'm unsure of the cam and valve train package i will be using as of now becasue i'm still talking to different engine builders. i have about $8000 to spend on the engine, and a few more to spend on the tranny, rearend, suspension...etc..
Old Apr 10, 2006 | 04:43 PM
WS Sick's Avatar
If you bought all those peices seperate from Summit themselves it would only be 1660.90 Plus 86 $ shipping.
That crank is a forged non-twist peice, very very nice. I seen one in a conventional SBC withstand over 900 ft pounds of torque. The
rods in that kit are the H beam, very nice as well.
Good kit for a N/A set-up, I would go with the -20cc pistons for a F/I set-up.
Old Apr 19, 2006 | 07:07 PM
jasonisdn's Avatar
get AI to cut your cam to match your head flow chart. better than guessing at it and missing out on some power. also let them put on your springs since they will have all the numbers needed for seat pressure and so on.
