E85?
Old May 23, 2006 | 10:01 PM
19z28camaro02's Avatar
Lightbulb E85?
Anybody know how E85 would run or is running in the LT1? 15% alcohol 105 octane??? MPG?
Old May 23, 2006 | 10:08 PM
OBE1 95Z28's Avatar
Re: E85?
E85 is 85% ethanol, 15% gasoline.
http://www.eere.energy.gov/afdc/e85t.../e85_fuel.html
Old May 23, 2006 | 10:12 PM
Re: E85?
i'm dyslexic
Old May 23, 2006 | 10:20 PM
turbo_Z's Avatar
Re: E85?
I think it burns too cool... relative to regular gasoline. That means you wont make as much power or worse.
Old May 23, 2006 | 10:22 PM
Re: E85?
more alcohol will cause it to run hotter, IE 105 octane
Old May 23, 2006 | 10:41 PM
OBE1 95Z28's Avatar
Re: E85?
Octane doesn't increase temperature, it just resists detonation (knock). It's also true that higher octane does not generate more horsepower in itself. What it does is allow you to increase your horsepower via higher compression ratio, super charger, nitrous, heads/cam and retune your engine to take advantage of the higher octane.
Old May 23, 2006 | 10:42 PM
Re: E85?
ok, so it wouldnt be smart to start running that on my current setup right?
Old May 23, 2006 | 10:53 PM
OBE1 95Z28's Avatar
Re: E85?
You can't run it, here's why:
http://www.e85fuel.com/e85101/faqs/conversion.php
Old May 23, 2006 | 10:54 PM
Dave89IROC's Avatar
Re: E85?
well, first,the stoich of E85 is richer then the 14.7:1 of gas, so you will run lean, which means hotter, second, you will be way down on power, third, your entire fuel system will fail, everything needs to be purposely selected to run such a high concentration on alcohol(I.E., all metal needs to be stainless steel, ect.)
Old May 24, 2006 | 01:20 AM
HardcoreRM125's Avatar
Re: E85?
Basically,
E85 sucks and is a bunch of hippie bull ****.
It might be neat for your next "green" vehicle, and is probably better than electric cars, but really, it sucks for any sort of performance. To maximize the performance for it, you need all new fuel tank/pump/lines/injector/pcm.
On the plus side, the power you loose from it not making as much energy per givin amount in comparison to gasoline, could likely be made up for since you could crank the compression ( Or boost on a FI motor ) up.
Irocz11389
Jul 23, 2008 06:06 PM
2001Firehawk
18
Dec 28, 2007 10:44 PM
Z284ever
10
Jun 22, 2006 09:06 AM
Z284ever
60
Feb 28, 2006 08:54 AM
