E3 Diamond Tech
Old Oct 3, 2007 | 07:49 PM
Timothy Piccuirro's Avatar
E3 Diamond Tech
did a search didn't see to much on those E3 plugs, I had tried them just for kicks (5.00 a pop), well they are horriblly manufactued , no quality control, gap is different on each one, ecletrode's are slanted, some beveled, some cross cut, and this was all in a selaed pack of four, Horrible! Can't comment on performance, but I would assume that these difference between each plug would greatly affect performace.
Old Oct 4, 2007 | 05:01 PM
Black 97 SS's Avatar
ya I bought em too but havent installed them. I wonder if the thier any good the saleman at Summit said they were new and good plugs. I wanted NGK but he talked me in too em and now im having second thoughts.
Old Oct 4, 2007 | 05:10 PM
In general, "gimmick" plugs are just that.... gimmicks that offer little (if anything) in the way of performance improvement. In fact, multiple electrode plugs will still only produce a single spark, depending on which tip of the ground strap is closest to the center electrode. And, the multiple electrodes will probably shroud the spark and reduce its effectiveness. Use a high quality "conventional" plug.... copper or platinum, depending on your need to extend plug life and the use of a power adder.
Old Oct 4, 2007 | 07:06 PM
Kevin Blown 95 TA's Avatar
You should return them if you can. Like Fred says, they are a gimmick plug and they have limited heat ranges and you cant set the gap - they do in fact block the spark from the fuel. I do R&D on different plugs and know the engineers at NGK and Champion - we see all kinds of these things which dont help the spark.
Old Oct 4, 2007 | 09:02 PM
There ****, I can't say its cause of them but after installing, I've had the same plug wire fry 3 times, there 8.8 mm Accel w/ DYI heat protectors
Fatdog2
Sep 16, 2015 11:04 PM
RX Speed Works
Sep 11, 2015 03:31 PM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
