e-cutout undercar wiring
Old Mar 30, 2003 | 09:09 PM
97droptopZ's Avatar
Exclamation e-cutout undercar wiring
I wired my DMH e-cutout a while back and used some tie straps and put them on certain parts of the car so the wire wouldnt hang. Well I took it off of the jack and the suspension pulled the plug out. I had it hanging for a while and it worked but looked crappy so I tie-strapped it to a round thing on the side of the wheel (sorry im not very technical) and it pulled it out after a little bit of driving. I am getting tired of trying to open my cutout and it not working and the plug enclosure is wearing down (it still works but the rubber is worn out around it. I just need a solution to all of this to make it look good and to where it wont pull out. Thanks.
Old Mar 31, 2003 | 05:47 PM
97droptopZ's Avatar
TTT
Old Mar 31, 2003 | 05:54 PM
Kain's Avatar
There's a few grommets under the car. One under the passenger and driver foot wells, along with a grommet under the spare tire well. You'd have to drill a hole in the rubber, and run the wire through it. Or you could drill a hole in the floor pan and put a rubber grommet from Home Depot in and run the wire through the most convienent place you can find.
Old Mar 31, 2003 | 06:04 PM
97droptopZ's Avatar
thats not what i mean, its all wired through the car i just need to know the best place to wire it from right before the rear axle to the grommet in the spare tire well. sorry about that.
Old Apr 1, 2003 | 08:19 PM
97droptopZ's Avatar
ttt
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
