E Brake light on??? Help.
Old Jun 21, 2004 | 09:11 PM
25thBird's Avatar
I recently finished installing my 3.73 gears. Put everything back in and went for a test drive. The car runs great, but I noticed my e-brake light is on. The e-brake handle is all the way down and I don't remember doing anything to the e-brake, other than taking the calipers off the rotors. The calipers stayed connected to the brake system the whole time though. My friend, who helped me, said it was possibly that the e-brake line was tugged a bit causing the light to go on. Anybody had this problem, or know what caused the light ot go on?
Old Jun 21, 2004 | 10:09 PM
25thBird's Avatar
Any help?
Old Jun 21, 2004 | 10:27 PM
Van's Avatar
Van
Your friend is right, it's the cable..... Check your Haines or Chiltons for seting your e-brake tension.
Old Jun 21, 2004 | 10:50 PM
25thBird's Avatar
So, the cable can be ajusted to settings?
Old Jun 21, 2004 | 10:57 PM
Mystic97Z's Avatar
i had that exact same problem, except for i was leaking brake fluid bad!!, put the car in the garage and did a head/cam install, when i started it up the light was still on ,and we fixed the brake line problem, bled the system and everything, my dad is a tech at a gm dealership and he said there is a switch that needs to be reset inside the brake thing behind the air intake, where all the brake lines attach to . not sure if thats the case w/ you, but we're having the SAME problem and thats my problem.
Old Jun 21, 2004 | 11:14 PM
25thBird's Avatar
I might try to look for the switch and see if that takes care of it. Anyone have a second opinion?
Old Jun 21, 2004 | 11:16 PM
Van's Avatar
Van
Mystic- The "thing" is your ABS module. If you don't have an ABS light nothing ABS related has been affected. When you bleed your brakes you MUST bleed your ABS module first.
25th- The e-brake is actually self adjusting and automatically compensates for cable slack, but you probably jacked up one of your cables doing the rearend swap. There actually is a free travel adjustment you can makefor free tavel in the handle.
Old Jun 21, 2004 | 11:21 PM
25thBird's Avatar
So does that mean the light may be on, without the line making pressure on the brakes?
Old Jun 21, 2004 | 11:25 PM
Van's Avatar
Van
Yes, but I would jack the rear end up and see if the wheels turn freely.
Old Jun 21, 2004 | 11:26 PM
25thBird's Avatar
If they don't, what else can I do to take care of the issue?
Old Jun 21, 2004 | 11:39 PM
Van's Avatar
Van
Check for cable freeplay at the calipers....
* car on jackstands
* disconnect cable from caliper
* remove e-brake lever return spring (the lever on the CALIPER not the one on the console)
* have friend in car lightly apply brakes (just enough to stop the wheel from spinning) have friend hold steady pressure until you're through....
* have friend pull e-brake handle until freeplay is removed
* measure .024 - .028 (feeler guage) between the e-brake caliper lever and the caliper....
Greater than spec = to much freeplay
Less than spec = too little
You really need a Haynes or Chiltons manual........
Old Jun 22, 2004 | 12:41 AM
25thBird's Avatar
I have one, but I haven't had a chance to take a look at it. I was just wondering if anyone else has been through this. I'm really grateful for all the input.
dluna333
15
Mar 13, 2015 12:30 PM
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
