E bay valve cover question
Old Feb 25, 2009 | 03:29 PM
a walker's Avatar
I know this topic has been beaten to death, but I have a problem...
I bought thse valve covers from "cowboyparts" on Ebay. They no longer list them. They don't fit very well over my Pro mags. Anybody else have them? What needed to be modded to get them to work? I can't tell if it's the "webbing" or if maybe the bolt hole tubes maybe too long, but when I set them on the heads, I can rock the covers back and forth. They're about a 1/4" from sitting flush, even with a gasket.
Here's a pic. I added the K&N breather and screw on oil cap, but the filler tube is welded on.
Old Feb 25, 2009 | 03:48 PM
maybe2fast's Avatar
big enough breather filter?
Old Feb 25, 2009 | 04:07 PM
Kevin Blown 95 TA's Avatar
Are your posilocks bouncing off the inside of the tops? There should be scratches if that is what's happening.
Old Feb 25, 2009 | 04:15 PM
a walker's Avatar
Haha yeah, I like the size. I actually picked the bigger size so it takes up a little more space to hide things.
Old Feb 25, 2009 | 04:17 PM
a walker's Avatar
Possibly. It's not even close enough where I can bolt them down and turn the engine over. Like I said, there's about a 1/4" gap, a little less when I use a gasket.
Old Feb 25, 2009 | 05:06 PM
deerslayinrenek's Avatar
I bought a set from another seller on ebay but the alternator hits them. This might sound really stupid but could you run an extra valve cover gasket?....good luck
Old Feb 25, 2009 | 05:36 PM
a walker's Avatar
I've heard of people doing that with cork gaskets, but I don't think it would work with the newer rubber gaskets.
Old Feb 25, 2009 | 06:56 PM
RamAir95TA's Avatar
I have these same valve covers with my Crane Golds and they fit perfectly. No fitment issues whatsoever.
Old Feb 25, 2009 | 07:51 PM
lt1-xjs's Avatar
Is there a removable oil baffle, if so remove it. My Proforms came with them, I just left them off.
Old Feb 25, 2009 | 08:17 PM
a walker's Avatar
Yeah, it has removeable baffles, and I never even tried to install em.
Old Feb 26, 2009 | 12:28 AM
a walker's Avatar
Aren't the Pro Mags wider at the trunion than Crane Golds? If I recall correctly, I believe my ARP 7/16 studs are longer than standard too now that I think about it. That could be my problem. However, I've been using modded stock covers with no problem.
Old Feb 27, 2009 | 10:41 AM
camarobird92's Avatar
I had to trim the trim the tube that the bolt goes through on my aluminum covers. The tube was too thick to fit between the rockers. The covers wouldn't fit down all the way.
Old Feb 27, 2009 | 12:48 PM
a walker's Avatar
Originally Posted by camarobird92
I had to trim the trim the tube that the bolt goes through on my aluminum covers. The tube was too thick to fit between the rockers. The rockers wouldn't fit down all the way.
That's kinda what I was thinking. Are your covers from ebay as well?
Old Mar 3, 2009 | 11:17 AM
I don't know the brand of my covers. They are just the tall ones for center bolt heads. I have really wide aluminum roller rockers though.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
Jul 4, 2005 05:00 PM
