Dynomax bullet muffler
Old Jan 28, 2005 | 07:12 PM
kicksZ28's Avatar
Question Dynomax bullet muffler
Does anyone have advice on replacing the single cat on my 95Z with a Dynomax bullet muffler. I have read on the message board that one or two people have talked about it. I want to remove the cat but don't want the car louder. Suggestions? Thanks
Old Jan 29, 2005 | 10:17 AM
kicksZ28's Avatar
Question Re: Dynomax bullet muffler
CONFUSED! After reading the messages I think I will replace the stock cat with a magnaflow. I don't want too loud and it sounds like there are many ways to try and quiet it. Now, the car has a single cat. What are its measurements? 2" in/out or 3"??? I have been told BOTH. Whats correct? Thanks for the help.
Old Jan 29, 2005 | 11:22 AM
maxboosteric's Avatar
I have a flowmaster exhaust with no cat.Its not loud enough for me,I'm going to change the exhaust soon.
Eric
Old Jan 29, 2005 | 12:10 PM
kicksZ28's Avatar
How used is the system and what model is it? Thanks
Old Jan 29, 2005 | 02:23 PM
Its just a 80 ser. muffler welded in to stock pipes.The guy before had a 2" straight pipe welded in place of the cat.It looks like the stock cat is a 2 1/4" in and out to me. The bullet muffler does very little a a system you may not even e able to tell its on.I suggest straight pipe the cat if you don't have emissions.Then go with a hooker system.Thats the way I'm goin.
Eric
Old Jan 29, 2005 | 04:41 PM
kicksZ28's Avatar
Yeah, I've looked at the Hookers today and will probably go with the Aerochamber style. They have pretty decent reviews and price isn't bad. They come in black which is the color of my car. It's a convert and totally black w/ no chrome or silver other than rims. Thanks
Old Jan 29, 2005 | 04:56 PM
groundpoundinlt's Avatar
i used to have a bullet muffler where the cat used to be and i also had a 80 series flow at the same time and it was perfect sounding...no gurgle or that loud popping
Old Jan 29, 2005 | 05:07 PM
96speed's Avatar
Sound volume is about as objective as asking someone whether or not Ashley Simpson is a good entertainer unless you have a db meter in your back pocket.
I have a 4" exhaust and my engine is a 385/hds/cam, etc. I let the car run with only the y-pipe connected. After installing a 4" bullet muffler behind the Ypipe I noticed a big decrease in volume and tone. The tone was much more throat and less "crackly." However, the overall volume (sound) was about the same as a wideopen Borla on a stock motor.
I installed the bullet in the ypipe and a 6" round welded Dynomax muffler (4" dia) in the stock muffler location and the car is MUCH quieter and extremely throaty sounding. I, personally, do not really like the way it sounds, but I've already gone through too many exhaust setups and true duals are not going to happen soon. Volume (sound) of my current setup would be comparable to a flowmaster catback on a cam'd car.
btw...Ashley Simpson is not a good entertainer .
Ryan
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
colts0455
Sep 22, 2015 02:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
