Dynoed today - new numbers...
Old May 2, 2004 | 03:30 PM
  #16
ZPaul2Fresh8's Avatar
Quazar Blue is a stock color. But wouldn't know myself if he had it repainted. Tony?
Old May 2, 2004 | 05:51 PM
  #17
TonyJ's Avatar
Stock Quasar blue. I'm condering the C5 Electron blue, though. It's a very nice blue. I like the Quasar just fine, though...
Old May 2, 2004 | 06:06 PM
  #18
sniffin94's Avatar
Tony I saw your car at DRE when Peter was getting it put back together, I just moved from the springs back to miami. Congrats on those numbers. Peter is the Man!!!!!!!! I am getting ready to have him build me a resleeved 406 lt-1, if anyone can do it he can. Have fun at the track and post some times for us.
Adam
Old May 2, 2004 | 06:13 PM
  #19
TonyJ's Avatar
Thanks Adam. Good luck with the 406. Miami is at sea level, so you should have some great times on that monster.
TJ
Old May 2, 2004 | 11:56 PM
  #20
Highlander's Avatar
That looks like an XE cam torque curve
Old May 3, 2004 | 02:10 AM
  #21
neil350's Avatar
Awesome power man, you use to live in Houston? I see from your page you bought your car from Bill Heard in Sugar Land.
Old May 3, 2004 | 03:12 AM
  #22
TonyJ's Avatar
Yea, lived there most of my life. Went to Sam Houston HS and UH. Worked for WorldCom in the Woodlands until 7 years ago when one of my ex-bosses lured me to Boulder during the dot.com days. Colorado sure beats Texas in the summer, but I miss Houston. I've got tons of friends there and there's nowhere that has a better car scene.
Old May 3, 2004 | 03:14 AM
  #23
TonyJ's Avatar
I'm supposed to keep it secret, so it's hidden under the Schneider logo on my home page... Don't tell anyone...
Old May 3, 2004 | 06:51 AM
  #24
[JFS]'s Avatar
Re: Dynoed today - new numbers...
Originally posted by TonyJ
Finally got the car done and back on the dyno this afternoon. New numbers: 632 rwhp, 554 rwtq on a Mustang dyno.
http://www.webpeak.com/~tony/bluez/dyno4.jpg
How was the injector duty cycle? Still using the 42lb lucas injectors? Stock ECM or an aftermatket ECU like FAST?
-j
Old May 3, 2004 | 08:10 AM
  #25
TonyJ's Avatar
Stock ecm, 42lb lucas, not sure about the duty cycle. I'll try to remember to check...
Old May 3, 2004 | 09:40 AM
  #26
[JFS]'s Avatar
I'd certainly be interested to know. Also what kind of fuel pressure? I have the same injectors and looking to see where they might max.
thanks
jon
Old May 3, 2004 | 04:34 PM
  #27
JordonMusser's Avatar
West South Central Moderator / Special Guest
keep in mind this is at high altitude. I would guess that 42s will not handle that much power at sea level!
Old May 3, 2004 | 04:39 PM
  #28
zhevy-1's Avatar
That's very true. We don't need as much fuel up here, but we do need more air.
-Goose
Old May 3, 2004 | 05:14 PM
  #29
Highlander's Avatar
Sorry... but i have a question... or maybe I disagree..
power is power... power needs fuel and more or less the same/ammount of air.. so.. either the engine is very efficient or 42 will hold the same power either sea level or 10000' in elevation...
Fuel is liquid and at pressure should be unaffected by ambient pressure...
If air is thinner its still the same MASS of air needed to support the power.. Engine are pumps...
Feel free to correct me.
Old May 3, 2004 | 06:07 PM
  #30
SStrokerAce's Avatar
Sounds good to me. Add on top of that you are still looking at 14psi that prety much takes care of the atmospheric differential. 42lbs with enough fuel pressure should handle the 750hp (flywheel that he is making)
Bret
